[Qgis-user] Qgis crashes while loading WMTS layers
Jeff Hubbs
jhubbslist at att.net
Wed Feb 12 07:01:55 PST 2020
Your understanding is essentially correct for most anything you will
likely encounter. Apps don't know or care about the memory
implementation that the operating system makes available.
On 2/12/20 7:35 AM, Patrick Dunford wrote:
> The assumption for me is that the operating system, in theory,
> presents a virtual memory model to applications, whereby the actual
> physical implementation is abstracted, such that when an application
> makes a request for more memory allocated, it is essentially
> transparent where the information is actually physically stored. Maybe
> that is not accurate?
