[Qgis-user] Qgis crashes while loading WMTS layers
Patrick Dunford
enzedrailmaps at gmail.com
Wed Feb 12 04:35:19 PST 2020
Sorry I don't know enough about virtual memory implementation to comment.
The only software I am sufficiently familiar with from experience is
Gimp, which has the setting where you can specify the size of the tile
cache. So for example I have a tile cache set to 200 GB. It starts with
physical RAM then pushes into the swap space.
I can monitor the resource use of the system with a widget displayed on
the panel on the computer. This shows CPU use, memory and swap space
use. From there I can watch the resource use of the system while doing
things. I can compare the resource usage being displayed for the system
with the Gimp dashboard.
The assumption for me is that the operating system, in theory, presents
a virtual memory model to applications, whereby the actual physical
implementation is abstracted, such that when an application makes a
request for more memory allocated, it is essentially transparent where
the information is actually physically stored. Maybe that is not accurate?
On 27/01/20 8:18 pm, Bo Victor Thomsen wrote:
> Hi Patrick -
> Swap space is an internal component the underlying operating system
> (OS) uses for handling memory request that exceeds the ram resources
> of the computer. A normal user program like QGIS has no "knowledge"
> about this facility and can't directly manipulate the swap system.
> As Jonathan describes, "swap" space for for other program is temporary
> file storage, usually placed in a specific directory (in windows
> designated by the environment variable %TEMP%). QGIS uses this
> directory too.
> A QGIS crash can be caused by running out of memory resources and/or
> temp file storage. However, that is result of a bad setup of your
> operating system, which can limit how much swap space, that can be
> allocated to memory hungry programs and the size of hard-disk used for
> swap space and/or temp storage
> So what to do:
> 1. Check memory consumption when using QGIS. Is it really using all
> the ram - memory and starting to swap ?
> 2. Check the setup of the swap space parameters. It it using a
> hard-disk which is running out of storage space.
> 3. Check the setup of the temp storage parameters. It it using a
> hard-disk which is running out of storage space ? Are the user
> allowed to allocate enough storage?
> (I can't be more specific not knowing the operating system you use)
> If the above checks out OK and you still have issues with QGIS crashing..
> The shift from QGIS 2.x to QGIS 3.x meant a complete change of the
> underlying graphics subsystem QT from ver 4.x to ver. 5.x (and a huge
> amount of other changes).
> One or more of those changes might cause a failure as you described.
> However, you have to check the above and then write an error issue
> (https://github.com/qgis/QGIS/issues) where you describe error
> messages, your specific setup like operating system and version, QGIS
> version and - if possible - test-data and project to replicate the issue.
> Med venlig hilsen / Kind regards
> Bo Victor Thomsen
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200213/c02e8e2e/attachment.html>
