[Qgis-user] SVG files in QGIS print layout
Newcomb, Doug
doug_newcomb at fws.gov
Thu Feb 13 06:05:35 PST 2020
Hi Folks,
I recently made up a poster using QGIS 3.10.2 and ran across a few issues with SVG files when using add image.
1) I use Inkscape 0.92.4 on windows to create customized North Arrows. When adding a large text N to the SVG file, it will not appear until I convert the text to a path using object to path.
2) Exporting a graph from R to an svg file using:
svg(file="graph_filename.svg", width=7, height=7).
When using add image to the print layout, none of the text associated with the graph is visible. Loading the svg file in Inkscape , the text shows up fine, but the convert text to a path method does not work on these files.
Before I dive into this further, is this known behavior that is being worked on? Do folks have an easy fix?
Yes, I could use png files, but vector graphics look better 🙂
Doug
Doug Newcomb - Cartographer
USFWS
551F Pylon Dr
Raleigh, NC
919-856-4520 ext. 14 doug_newcomb at fws.gov<mailto:doug_newcomb at fws.gov>
NOTE: This email correspondence and any attachments to and from this sender is subject to the Freedom of Information Act (FOIA) and may be disclosed to third parties.​
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200213/5a58f06a/attachment.html>
