[Qgis-user] QGIS and PostGIS, dimensions problems
Matthias Kuhn
matthias at opengis.ch
Fri Feb 14 02:04:15 PST 2020
Hi Jakob,
When adding a new Layer, QGIS checks the column definition in postgis
and configures it accordingly.
I suspect either of the following:
- You have a project created on an old table definition and the table
was altered later
- There is a misconfiguration in your column definition (-> ST_PointZ is
a function, so I suspect you are using a view as layer, which might have
been created as 2D and writing to a 3D table or similar).
Matthias
On 2/14/20 8:05 AM, Jakob Götesson wrote:
> Hello everyone!
> I have a point-layer in Postgis v12 which is ST_pointZ according to
> PostGIS.
> When creating a new point in QGIS and then tries to save it, I get an
> error:
> ”Column has Z dimension but geometry does not”
> When looking in to the object identifier the derived attributes only
> contains X and Y. However, the rest of the points that loads from the
> database has a Z-value set to 0 attached to them. So i get that my
> created point dosen´t have a Z-value.
> Isn't it possible to create new data in 3 dimensional tables from
> Postgis in QGIS? Even with a deafult value of 0, I don´t even need to
> specify the Z-value at this moment.
> (Found a work around but I prefer not to use this:
> If I save the QGIS-project and open the .qgs-file in text editor and
> look into the datasource-tag for the the layer I have:
> /type=Point/
> When changing this to:
> /type=PointZ/
> saves the project and try to create a new object, it works fine.)
> Regards
> *Jakob Götesson
> *GIS-ingenjör
> *Borås Stad* – Samhällsbyggnadsförvaltningen
> Kungsgatan 55, 501 80 Borås
> 033-35 84 66
> boras.se
> facebook.com/borasstad**
> När du kommunicerar med Borås Stad behandlar vi dina personuppgifter.
> För mer information hur Borås Stad hanterar personuppgifter se
> boras.se/publänk till annan webbplats <https://www.boras.se/pub>
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200214/26737d63/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200214/26737d63/attachment.png>
