[Qgis-user] gdal2tiles not included in QGIS 3.10.2
Randal Hale
rjhale at northrivergeographic.com
Fri Feb 14 08:40:53 PST 2020
It has been a bit since I was running 18.04 but you may want to try
running: sudo apt-get install gdal-bin (possibly with the python-gdal
package also)
On 2/14/20 11:08 AM, Nick Hopton wrote:
> In the last couple of days I have done a clean install of Ubuntu 18.04.4 LTS,
> followed by an install of QGIS version 3.10.2.
> I now find that when I try to use gdal2tiles either from the Toolbox or from
> a terminal I get the message "command not found". Thus, it would appear that
> gdal2tiles was not installed as part of the QGIS installation.
> Should I report this as a bug? (I'm always nervous of reporting bugs without
> checking first).
> It there a way around the problem? - I'm using gdal2tiles quite heavily at
> present.
> QGIS version
> 3.10.2-A Coruña
> QGIS code revision
> 616ad4531b
> Compiled against Qt
> 5.9.5
> Running against Qt
> 5.9.5
> Compiled against GDAL/OGR
> 2.2.3
> Running against GDAL/OGR
> 2.2.3
> Compiled against GEOS
> 3.6.2-CAPI-1.10.2
> Running against GEOS
> 3.6.2-CAPI-1.10.2 4d2925d6
> Compiled against SQLite
> 3.22.0
> Running against SQLite
> 3.22.0
> PostgreSQL Client Version
> 10.10 (Ubuntu 10.10-0ubuntu0.18.04.1)
> SpatiaLite Version
> 4.3.0a
> QWT Version
> 6.1.3
> QScintilla2 Version
> 2.10.2
> PROJ.4 Version
> 493
> OS Version
> Ubuntu 18.04.4 LTS
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user mailing list
Randal Hale
(p) 423.653.2611
http://www.northrivergeographic.com
