[Qgis-user] gdal2tiles not included in QGIS 3.10.2
Bernd Vogelgesang
bernd.vogelgesang at gmx.de
Fri Feb 14 08:34:45 PST 2020
Hi Nick,
My gdal version is 3.0.2 and there is a gdal2tiles.py available in the
terminal
My stuff is installed with ubuntu-unstable
QGIS version
3.10.2-A Coruña
QGIS code revision
616ad4531b
Compiled against Qt
5.9.5
Running against Qt
5.9.5
Compiled against GDAL/OGR
3.0.2
Running against GDAL/OGR
3.0.2
Compiled against GEOS
3.8.0-CAPI-1.13.1
Running against GEOS
3.8.0-CAPI-1.13.1
Compiled against SQLite
3.22.0
Running against SQLite
3.22.0
PostgreSQL Client Version
10.10 (Ubuntu 10.10-0ubuntu0.18.04.1)
SpatiaLite Version
4.3.0a
QWT Version
6.1.3
QScintilla2 Version
2.10.2
Compiled against PROJ
6.2.1
Running against PROJ
Rel. 6.2.1, November 1st, 2019
OS Version
Linux Mint 19.3
Active python plugins
qProf;
quick_map_services;
qfieldsync;
processing_saga_nextgen;
qgis_resource_sharing;
qgis2web;
processing_whitebox;
LecoS;
MetaSearch;
db_manager;
processing
Am 14.02.20 um 17:08 schrieb Nick Hopton:
> In the last couple of days I have done a clean install of Ubuntu 18.04.4 LTS,
> followed by an install of QGIS version 3.10.2.
> I now find that when I try to use gdal2tiles either from the Toolbox or from
> a terminal I get the message "command not found". Thus, it would appear that
> gdal2tiles was not installed as part of the QGIS installation.
> Should I report this as a bug? (I'm always nervous of reporting bugs without
> checking first).
> It there a way around the problem? - I'm using gdal2tiles quite heavily at
> present.
> QGIS version
> 3.10.2-A Coruña
> QGIS code revision
> 616ad4531b
> Compiled against Qt
> 5.9.5
> Running against Qt
> 5.9.5
> 2.2.3
> 2.2.3
> 3.6.2-CAPI-1.10.2
> 3.6.2-CAPI-1.10.2 4d2925d6
> 3.22.0
> 3.22.0
> SpatiaLite Version
> 4.3.0a
> QWT Version
> 6.1.3
> QScintilla2 Version
> 2.10.2
> PROJ.4 Version
> 493
> OS Version
> Ubuntu 18.04.4 LTS
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user mailing list
