[Qgis-user] [QGIS-Developer] Zoom to Scale Plugin - Should we include it on qgis.org?
Richard Duivenvoorde
rdmailings at duif.net
Fri Feb 21 00:49:21 PST 2020
On 2/21/20 7:00 AM, Alexander Bruy wrote:
> Also QGIS allows to create custom scale lists and switch between scales
> by selecting desired value from the scale combobox in the main window
> statusbar.
Hi Alex,
As a argument against using the custom scale switch: in my country we
have a local tile-scheme [0] with a 'strange' set of scales.
So adding them means you cannot use it anymore for other scale-set's
(like Google Mercator scheme).
My little treewidget would make it possible to have a layer with 2
base/reference layers in different tile-schemes, and still make it
possible to always have a crisp scale (by making the corresponding layer
active).
@Nyall, in my case you can choose to ALWAYS zoom to the given scales
with a checkbox.
Regards,
http://www.qgis.nl/2015/06/14/change-predefined-scales/?lang=en
