[Qgis-user] Geopackage decimal lenght and precision not available
Patrick St-Hilaire ps.vlachute at gmail.com
Wed Feb 26 06:27:18 PST 2020
I solved the problem with this function
round("ELEV",2)
Le mar. 25 févr. 2020 à 14:55, Bernd Vogelgesang <bernd.vogelgesang at gmx.de>
a écrit :
> As far as I know sqlite-based formats do not need such settings. I think
> the need to do so in Shape files derives from those ancient times when each
> byte of memory was so expensive, that you had to squeeze your data to the
> lowest footprint possible.
> Am 25.02.20 um 20:23 schrieb Patrick St-Hilaire:
> Hi,
> I started using geopackage instead of shapefile, but I can't use length and
> precision decimal with geopackage. Is this normal? See image screenshot
> It's in french language
> I use the 3.4.5 Qgis version.
> Qgis-user mailing listQgis-user at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200226/2631cae6/attachment.html>
