[Qgis-user] Export to GeoPDF
Nyall Dawson
nyall.dawson at gmail.com
Wed Feb 26 15:35:57 PST 2020
On Tue, 25 Feb 2020 at 17:39, Christoph Jung <jagodki.cj at gmail.com> wrote:
> Hello everyone,
> When I export a map to GeoPDF, the order and groups of my layers will be lost in the GeoPDF. It seems, that the pdf sorts the layers alphabetically and vector layers over raster layers. Is there a possibility to tell QGIS, that the order and groups of layers from my map should be exported to GeoPDF too?
That shouldn't be the case (and there's unit tests in place checking
this). Could you try first a different PDF reader, and if you still
see this, open a bug report with your project attached?
Nyall
