[Qgis-user] Export to GeoPDF
    Christoph Jung
    jagodki.cj at gmail.com
    Wed Feb 26 22:21:30 PST 2020
Hi Nyall,
Thank you for your answer. I will test it during the next days with different layers and also under macOS to describe the problem as much detailed as possible.
Christoph
> Am 27.02.2020 um 00:36 schrieb Nyall Dawson <nyall.dawson at gmail.com>:
> On Tue, 25 Feb 2020 at 17:39, Christoph Jung <jagodki.cj at gmail.com> wrote:
>> Hello everyone,
>> When I export a map to GeoPDF, the order and groups of my layers will be lost in the GeoPDF. It seems, that the pdf sorts the layers alphabetically and vector layers over raster layers. Is there a possibility to tell QGIS, that the order and groups of layers from my map should be exported to GeoPDF too?
> That shouldn't be the case (and there's unit tests in place checking
> this). Could you try first a different PDF reader, and if you still
> see this, open a bug report with your project attached?
> Nyall
