[Qgis-user] Micro-Geometry Problems
Kirk Schmidt kirk at nortekresources.com
Thu Jan 16 06:48:54 PST 2020
Hi All:
This is a classic digitizing issue that can be corrected with GRAS  as Harrisou suggests.  If the layer does not get cleaned during the import process, you can use the grass functions v.build and v.clean to fix the digitizing slivers and incomplete intersections.
Kirk Schmidt
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of DelazJ
Sent: Wednesday, January 15, 2020 3:45 AM
To: dhdeangelis at comhem.se
Cc: qgis-user
Subject: Re: [Qgis-user] Micro-Geometry Problems
There's also a "snap geometries to layer" Processing algorithm in QGIS that could be worth a look.
https://docs.qgis.org/3.4/en/docs/user_manual/processing_algs/qgis/vectorgeometry.html#snap-geometries-to-layer
Regards,
Harrissou
Le mer. 15 janv. 2020 à 08:34, Hernán De Angelis <dhdeangelis at comhem.se> a écrit :
Steve,
In my opinion this is where GRASS topological vector model shines. One suggestion would be to import these vectors into a GRASS location and let GRASS clean the polygons and fix the topology automatically during import. My experience with similar problems is that after the import and cleaning there would be few if any errors of the sort you mention. In the worst case any surviving error is found it could in principle be solved by deleting the stubborn surface and digitizing it again. It will definitely not take two weeks of work!
Good luck!
H.
On 2020-01-14 22:51, smiller192 at cfl.rr.com wrote:
All-
I have digitized a land use/land cover layer as individual polygons.  The snap options were used and, for most vertices, the snap was precise.  A vertex in polygon A has a precise match to a vertex in neighboring polygon B.
But in 582 out of 2799 polygons, there are mis-matches in adjoining vertices that are only evident if you zoom into the layer at a magnification (i.e., a scale) of from 20000:1 to 40000 to 1.  I have spent a couple of weeks trying to remedy these by hand using the Vertex Tool and other means.  My question is this: is there an automated way in QIS to detect and remedy these situations?
Thanks,
Steve Miler
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200116/8348c62e/attachment.html>
