[Qgis-user] Reclassifying NDWI image generated from Landsat 8
Richard McDonnell
richard.mcdonnell at opw.ie
Fri Jan 24 01:32:20 PST 2020
You can try the SAGA tool Reclassify Values Simple, available under Processing Toolbox.
Set the required Replace Condition, Use the Lookup Table to set your value bands and required outputs.
Hope this helps,
Regards,
Richard
Richard McDonnell MSc GIS, FME Certified Professional
FRM Data Management
Oifig na nOibreacha Poiblí
Office of Public Works
Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36
Jonathan Swift Street, Trim, Co Meath, C15 NX36
M +353 87 688 5964 T +353 1 647 6543
https://www.opw.ie
To send me files larger than 30MB, please use the link below https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
Email Disclaimer: https://www.opw.ie/en/disclaimer/
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of McArd Mlotha
Sent: 23 January 2020 23:49
To: Qgis-user at lists.osgeo.org
Subject: [Qgis-user] Reclassifying NDWI image generated from Landsat 8
Hello,
I run NDWI using Landsat 8 and now I would like to reclassify the output separating water from land. Here is what I would like to reclass:
-0.994 to 0.1 = 0 and
0.1 to 1 = 1
but I cannot find a tool to use in QGIS. Reading comments online, it seems "the possible reclassifies" in QGIS do not handle real data type.
Is there a way to do this in QGIS?
Thank you in advance,
Joseph
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200124/67dd234d/attachment.html>
