[Qgis-user] Experience in QGIS as App-V installation?
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Wed Jul 1 00:27:05 PDT 2020
I don’t experience with app-v but I do have experience with huge spatial data set and QGIS. If you want to run QGIS in a virtual machine (I imagine this is the case), you may be able to do this with small project. For anything big, I believe the requirements of huge dataset and the computational power needed to processes them will find multiple bottle necks in virtual environments. For an effective GIS, you need lots of memory, multiple cpu cores, ssd speed data access and direct access to a real, unvirtualised GPU. If you have all that in the virtual environments, It could probably work.
Nicolas Cadieux
Ça va bien aller!
> Le 30 juin 2020 à 04:25, Andreas Neumann <a.neumann at carto.net> a écrit :
> Hi,
> Does someone on this lists (user and developer list) have experience with installing QGIS in App-V mode?
> Are there any blockers or problems? Is this a recommended way to run QGIS on Windows?
> Thanks for sharing any experiences you have with this technology.
> Andreas
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200701/0ee7160f/attachment.html>
