[Qgis-user] Experience in QGIS as App-V installation?
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Wed Jul 1 07:42:34 PDT 2020
In that case, multiple cpu Cores should be used for each machine as rendering uses multiple core by default. I would try with 4 cores. I would allocate no less than 8 to 16 GB per machine. Data access speed could be a big issue, specially if they are on a samba type file server. GPU processing was still experimental in QGIS so direct access to a GPU can probably be left out of the equation unless major changes have been done on this in the latest versions.
QGIS it self is not heavy. It’s the data that can kill even the best workstations.
Good luck
Nicolas Cadieux
Ça va bien aller!
> Le 1 juill. 2020 à 05:19, Andreas Neumann <a.neumann at carto.net> a écrit :
> Hi Nicolas,
> Yes, I understand that it will need a relatively powerful server. But it will be mainly for editing and viewing tasks (all 2d, no 3d) with normally no complex analysis tasks.
> Most of our Windows clients are virtualized through Citrix anyway - so there won't be too much difference in this respect, I guess.
> We will test it and see. Thanks for sharing your thoughts,
> Andreas
>> On 2020-07-01 09:27, Nicolas Cadieux wrote:
>> Hi,
>> I don't experience with app-v but I do have experience with huge spatial data set and QGIS. If you want to run QGIS in a virtual machine (I imagine this is the case), you may be able to do this with small project. For anything big, I believe the requirements of huge dataset and the computational power needed to processes them will find multiple bottle necks in virtual environments. For an effective GIS, you need lots of memory, multiple cpu cores, ssd speed data access and direct access to a real, unvirtualised GPU. If you have all that in the virtual environments, It could probably work.
>> Nicolas Cadieux
>> Ça va bien aller!
>>> Le 30 juin 2020 à 04:25, Andreas Neumann <a.neumann at carto.net> a écrit :
>>> Hi,
>>> Does someone on this lists (user and developer list) have experience with installing QGIS in App-V mode?
>>> Are there any blockers or problems? Is this a recommended way to run QGIS on Windows?
>>> Thanks for sharing any experiences you have with this technology.
>>> Andreas
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200701/4cb86e09/attachment.html>
