[Qgis-user] What Happened to GRASS in QGIS
Alexandre Neto
senhor.neto at gmail.com
Mon Jul 6 06:39:47 PDT 2020
Are you on windows? Did you start QGIS using the QGIS with GRASS shortcut?
Alexandre Neto
QGIS Support
http://www.qcooperative.net
A domingo, 5/07/2020, 22:47, C Hamilton <adenaculture at gmail.com> escreveu:
> I don't often use GRASS in QGIS, but there are some algorithms I need from
> time to time. I just tried running them from processing in QGIS 3.14 and I
> get this error.
> This algorithm cannot be run :-(
> The specified GRASS 7 folder "C:\OSGEO4~1\bin\bin" does not contain a
> valid set of GRASS 7 modules. Please, go to the Processing settings dialog,
> and check that the GRASS 7 folder is correctly configured
> How do I fix this?
> Thanks,
> Calvin
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200706/a985e0d8/attachment.html>
