[Qgis-user] What Happened to GRASS in QGIS
C Hamilton adenaculture at gmail.com
Mon Jul 6 07:53:46 PDT 2020
Thanks for that reminder. I am on Windows and for some reason the OSGeo4W
is no longer including links in the menu for QGIS with GRASS.
On Mon, Jul 6, 2020 at 9:40 AM Alexandre Neto <senhor.neto at gmail.com> wrote:
>  Hi,
> Are you on windows? Did you start QGIS using the QGIS with GRASS shortcut?
> Alexandre Neto
> QGIS Support
> http://www.qcooperative.net
> A domingo, 5/07/2020, 22:47, C Hamilton <adenaculture at gmail.com> escreveu:
>> I don't often use GRASS in QGIS, but there are some algorithms I need
>> from time to time. I just tried running them from processing in QGIS 3.14
>> and I get this error.
>> This algorithm cannot be run :-(
>> The specified GRASS 7 folder "C:\OSGEO4~1\bin\bin" does not contain a
>> valid set of GRASS 7 modules. Please, go to the Processing settings dialog,
>> and check that the GRASS 7 folder is correctly configured
>> How do I fix this?
>> Thanks,
>> Calvin
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200706/057e9774/attachment.html>
