[Qgis-user] export a composite image to kmz format
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Thu Jul 9 17:08:15 PDT 2020
I believe only Vector layers are supported. Kmz is a zipped kml.
Nicolas
https://gdal.org/drivers/vector/kml.html
Keyhole Markup Language (KML) is an XML-based language for managing the display of 3D geospatial data. KML has been accepted as an OGC standard, and is supported in one way or another on the major GeoBrowsers. Note that KML by specification uses only a single projection, EPSG:4326. All OGR KML output will be presented in EPSG:4326. As such OGR will create layers in the correct coordinate system and transform any geometries.
At this time, only vector layers are handled by the KML driver. (there are additional scripts supplied with the GDAL project that can build other kinds of output)
Nicolas Cadieux
Ça va bien aller!
> Le 9 juill. 2020 à 19:07, carlos h <carloslda256 at gmail.com> a écrit :
> Hello! I am with QGis version 3.10.x.
> How can I export a composite image to kmz format?
> Thank you
> CA
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200709/6f7ebf34/attachment.html>
