[Qgis-user] Closest Distance of a point within a polygon to the closest part of that polygon and the name of the adjacent polygon with the common boarder
Christoph Jung
jagodki.cj at gmail.com
Fri Jul 10 01:40:25 PDT 2020
Hello Dave,
With the plugin “Closest Points” you can calculate the closest points on your polygons for each point. The distance and the IDs of the input point and the closest polygon will also be stored in the result layer to create joins between the result layer and your input data.
Sincerely,
Christoph
> Am 10.07.2020 um 06:18 schrieb David Kabay <dkabay at iinet.net.au>:
> Hi
> I have a challenge. I have 2 vector data sets. One is point vectors (Occurrence of a soil fungus Pc at a point +red with a year of sampling as a label) and polygon vectors that show the various surface geologies in an area ( the name is on the boundary (purple) Inside of the one it is e.g. S10, S8 Mc1 etc.
> QGIS can give me the number of Pc sample points in each polygon which I have done. I want to be able to get the distance from the point to the NEAREST boundary and the other name of the surface geology of the closest adjoining polygon I want it for all Pc points
> How do I do that in QGIS ??
> Thanks Dave
> Dave Kabay
> 19A Priestley Street
> Embleton WA 6062
> Phone 08 6142 6756 Mob 0417 950 508
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200710/8311d2ee/attachment-0001.html>
