[Qgis-user] New Apple Macintosh ARM Chipsets
Michael Goldstein
michael.goldstein7 at gmail.com
Fri Jul 10 06:51:48 PDT 2020
Thanks to everyone who responded to my email.
I'm currently running a 27" late-2013 iMac, whose life I extended by
upgrading the boot drive to SSD. While it's still a capable machine, I
don't think it has 2+ more years left in it. Sigh. So I may be forced
to make the ARM transition sooner rather than later, unless I decide to
upgrade to an Intel iMac instead (which is not so desirable given my
other commitments to the Apple eco-system)..
I've been running QGIS on Macs since 1.x. Over the years Mac support
has been spotty even into the 3.xx era. For example, a few months ago I
had to run the Windows version in a VM to export a georeferenced PDF.
That was a python issue, I think... QGIS 3.8 needed a later version of
phython which didn't then exist for Mac. That said, a sincere thanks to
kyngchaos making it possible to run on Mac at all for many of those years!
Good news that the port to ARM should be straight-forward. I do hope it
becomes a priority because the inherent energy efficiency of the ARM
chipsets should make for some compelling hardware, particularly for
laptop users.
Finally, I would like to volunteer to write some documentation. What's
the best way to do that?
Michael
qgis-user-request at lists.osgeo.org wrote on 7/10/20 2:33 AM:
> Send Qgis-user mailing list submissions to
> qgis-user at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> https://lists.osgeo.org/mailman/listinfo/qgis-user
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> qgis-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Qgis-user digest..."
> Today's Topics:
> 1. export a composite image to kmz format (carlos h)
> 2. Re: New Apple Macintosh ARM Chipsets
> (Priv.-Doz. Dr. Maria Shinoto)
> 3. Re: export a composite image to kmz format (Nicolas Cadieux)
> 4. Re: Closest Distance of a point within a polygon to the
> closest part of that polygon and the name of the adjacent polygon
> with the common boarder (David Kabay)
> 5. Re: New Apple Macintosh ARM Chipsets (Saber Razmjooei)
> 6. Re: New Apple Macintosh ARM Chipsets (Andreas Neumann)
> Message: 1
> Date: Thu, 9 Jul 2020 17:07:14 -0600
> From: carlos h <carloslda256 at gmail.com>
> To: qgis-user <qgis-user at lists.osgeo.org>
> Subject: [Qgis-user] export a composite image to kmz format
> Message-ID:
> <CAKrv22yPfr=BTXtpsFpmGVkUMsumRuqjYJbPvUxH2zKrLHq4NQ at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> Hello! I am with QGis version 3.10.x.
> How can I export a composite image to kmz format?
> Thank you
> CA
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200709/2ee2982f/attachment-0001.html>
> Message: 2
> Date: Thu, 9 Jul 2020 23:34:00 +0000
> From: "Priv.-Doz. Dr. Maria Shinoto"
> <maria.shinoto at zaw.uni-heidelberg.de>
> To: Michael Goldstein <michael.goldstein7 at gmail.com>
> Cc: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
> Subject: Re: [Qgis-user] New Apple Macintosh ARM Chipsets
> Message-ID:
> <1B8A9DDB-C742-4B5A-A674-19BB1661A656 at zaw.uni-heidelberg.de>
> Content-Type: text/plain; charset="us-ascii"
> Hi,
> earlier posts said that a port to ARM architecture should not be too big of a problem.
> I do not remember the details, but my conclusion was: Just wait, no problems to expect.
> But I have to admit that I own a MacBook Pro from 2019 and do not plan to change in the next five or more years. I would hesitate to buy ARM architecture in the next 12 months anyway.
> Best,
> Maria
>> Am 09.07.2020 um 22:57 schrieb Michael Goldstein <michael.goldstein7 at gmail.com>:
>> I've just joined this email list, so if this has been covered earlier, I apologize. Also, let me know if I should be directing this question to a different mailing list (Developer list?).
>> Do plans exist to port QGIS to the new Apple Mac ARM architecture?
>> While I am not technical enough to help with the coding/re-compiling, I am a good documentation writer and would be happy to help document a new Mac release. How should I volunteer?
>> Michael
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Message: 3
> Date: Thu, 9 Jul 2020 20:08:15 -0400
> From: Nicolas Cadieux <njacadieux.gitlab at gmail.com>
> To: carlos h <carloslda256 at gmail.com>
> Cc: qgis-user <qgis-user at lists.osgeo.org>
> Subject: Re: [Qgis-user] export a composite image to kmz format
> Message-ID: <2EE34401-012D-46DE-9234-0BB0F55C2DBF at gmail.com>
> Hi,
> I believe only Vector layers are supported. Kmz is a zipped kml.
> Nicolas
> https://gdal.org/drivers/vector/kml.html
> Keyhole Markup Language (KML) is an XML-based language for managing the display of 3D geospatial data. KML has been accepted as an OGC standard, and is supported in one way or another on the major GeoBrowsers. Note that KML by specification uses only a single projection, EPSG:4326. All OGR KML output will be presented in EPSG:4326. As such OGR will create layers in the correct coordinate system and transform any geometries.
> At this time, only vector layers are handled by the KML driver. (there are additional scripts supplied with the GDAL project that can build other kinds of output)
> Nicolas Cadieux
> Ça va bien aller!
>> Thank you
>> CA
> URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200709/6f7ebf34/attachment-0001.html>
> Message: 4
> Date: Mon, 10 Aug 2020 12:19:23 +0800
> From: "David Kabay" <dkabay at iinet.net.au>
> To: <Qgis-user at lists.osgeo.org>
> Subject: Re: [Qgis-user] Closest Distance of a point within a polygon
> to the closest part of that polygon and the name of the adjacent
> polygon with the common boarder
> Message-ID: <008501d66ecd$6e40a650$4ac1f2f0$@net.au>
> Hi
> I have a challenge. I have 2 vector data sets. One is point vectors
> (Occurrence of a soil fungus Pc at a point +red with a year of sampling
> as a label) and polygon vectors that show the various surface geologies in
> an area ( the name is on the boundary (purple) Inside of the one it is
> e.g. S10, S8 Mc1 etc.
> QGIS can give me the number of Pc sample points in each polygon which I have
> done. I want to be able to get the distance from the point to the NEAREST
> boundary and the other name of the surface geology of the closest adjoining
> polygon I want it for all Pc points
> How do I do that in QGIS ??
> Thanks Dave
> Dave Kabay
> 19A Priestley Street
> Embleton WA 6062
> Phone 08 6142 6756 Mob 0417 950 508
> URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200810/6ab731f1/attachment.html>
> Message: 5
> Date: Fri, 10 Jul 2020 06:49:22 +0100
> From: Saber Razmjooei <saber.razmjooei at lutraconsulting.co.uk>
> To: "Priv.-Doz. Dr. Maria Shinoto"
> Cc: Michael Goldstein <michael.goldstein7 at gmail.com>,
> Message-ID:
> <CAH=WbRAaoAYRyerVJcUNqok2ryNeAt7Z1XNE=TuvfpOyW0Mn0Q at mail.gmail.com>
> Hi
> We have already ported QGIS to iOS for Input app (https://inputapp.io and
> https://github.com/lutraconsulting/input-sdk/tree/master/ios). iOS is ARM
> based architecture. Hence, it should be possible and straightforward to
> support the new mac ARM too. It also depends on the upstream support from
> Apple, Qt, Python...
> Kind regards
> Saber
> On Fri, 10 Jul 2020 at 00:33, Priv.-Doz. Dr. Maria Shinoto <
> maria.shinoto at zaw.uni-heidelberg.de> wrote:
>> Hi,
>> of a problem.
>> problems to expect.
>> Best,
>> Maria
>>> Michael
Michael Goldstein
609-638-3250 (m)
