[Qgis-user] What am I missing? Python plugins not available.
Thayer Young
thayeray at yahoo.com
Mon Jul 20 10:14:27 PDT 2020
Hi Frank,
Assuming that you are using the main MacOS QGIS installer from QGIS.org: Python should be packaged with QGIS, and QGIS should be using its own python, so the Terminal commands will probably not be helpful.
I think you may have a repository problem, or not be connected to the internet? In the Plugins dialog, click on the Settings tab and in the "Plugin Repositories" section check that you have this URL listed and that its status is "connected":https://plugins.qgis.org/plugins/plugins.xml?qgis=3.8
You may need to scroll down in the dialog to see the buttons underneath with which you can: add, edit or reconnect to the repository.
-Thayer
On 7/17/20 4:15 PM, F@ wrote:
> Hi list,
> This is new to me so apologies if something not complete.
> I am on a iMac late 2013 running MacOS Sierra 10.12.6
> I have the standard stable QGIS install 3.8.1 (full info below)
> I wish to upload a map to qgiscloud or package it so that another user can download the map.
> For some reason I am missing the python plugins.
> Any help/guidance very welcome.
> I have looked into installing an older copy of QGIS for the macOS, but worried I will lose all my work.
> Warm regards,
> Frank
> Full QGIs info:
> QGIS version
> 3.8.1-Zanzibar
> QGIS code revision
> dcd95cc648 <https://github.com/qgis/QGIS/commit/dcd95cc648>
> Compiled against Qt
> 5.12.3
> Running against Qt
> 5.12.3
> Compiled against GDAL/OGR
> 2.4.1
> Running against GDAL/OGR
> 2.4.1
> Compiled against GEOS
> 3.7.2-CAPI-1.11.2
> Running against GEOS
> 3.7.2-CAPI-1.11.2 b55d2125
> PostgreSQL Client Version
> 11.3
> SpatiaLite Version
> 4.3.0a
> QWT Version
> 6.1.4
> QScintilla2 Version
> 2.11.1
> Compiled against PROJ
> 5.2.0
> Running against PROJ
> Rel. 5.2.0, September 15th, 2018
> OS Version
> macOS Sierra (10.12)
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200720/edf5e1c1/attachment.html>
