[Qgis-user] Question
Alireza Ghalavand
arghalavand at gmail.com
Tue Jul 21 04:18:17 PDT 2020
Hello,
Qgis Error “Raster layer Cannot instantiate the 'gdal' data provider” in qt
c++
<https://stackoverflow.com/questions/63010283/qgis-error-raster-layer-cannot-instantiate-the-gdal-data-provider-in-qt-c>
When I am trying to add a raster layer, I get this error from
QgsRasterLayer::IsValid()!!! Can anybody tell me why this happens!? I am
beginner in qgis, so could you please explain in detail. the first func
"onAddLayer" used for Add button clicked and second func is defined for
adding a raster layer.
*my code:*
void MainWindow::onAddLayer()
const auto path = QFileDialog::getOpenFileName(this, "SELECT GIS MAP
LAYER", QDir(
_lastMapDir).path());
if (path.isEmpty() || path.isNull())
return;
addRasterLayer(path);
_lastMapDir = QDir(path).canonicalPath();
void MainWindow::addRasterLayer(const QFileInfo &info)
LOG(QString("adding map layer %1").arg(info.filePath()));
QString errMsg;
// if (!QgsRasterLayer::isValidRasterFileName(info.filePath(), errMsg))
// LOG(errMsg);
// return;
QScopedPointer<QgsRasterLayer> layer(new QgsRasterLayer(info.filePath(),
info.baseName()));
//layer->setDataProvider("gdal"); // Added by ArGhalavand
if (!layer->isValid())
LOG(QString("failed to add layer (%1)").arg(layer->error().message(
QgsErrorMessage::Format::Text)));
return;
save("last_layer_path", info.filePath(), "gis");
_rasterProvider = layer->dataProvider();
_mapCanvas->freeze(true);
auto item = QgsMapCanvasLayer(layer.take(), true);
_mapCanvas->setExtent(item.layer()->extent());
QgsMapLayerRegistry::instance()->addMapLayer(item.layer(), true);
_mapCanvas->setLayerSet(QList<QgsMapCanvasLayer>() << item);
_mapCanvas->freeze(false);
_mapCanvas->setVisible(true);
_mapCanvas->refresh();
statusBar()->showMessage(QString("%1 LOADED").arg(info.fileName()), 3000);
*With Best Regards,*
Alireza Ghalavand
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200721/b986adb7/attachment.html>
