[Qgis-user] Polylines not visible
Rebecca Reid
becjane87 at gmail.com
Sat Jul 25 19:54:24 PDT 2020
I’m a new QGIS user, and I’ve been running through the QGIS Training Manual. In Module 4.2.2., as part of creating a print layout, you add a polygon and several polylines to create a header ( https://docs.qgis.org/3.10/en/docs/training_manual/map_composer/dynamic_layout.html#moderate-fa-creating-the-dynamic-header <https://docs.qgis.org/3.10/en/docs/training_manual/map_composer/dynamic_layout.html#moderate-fa-creating-the-dynamic-header> ). The polygon (rectangle) is always visible, but the polylines used to break the header up into sections are only visible when selected, for some reason. If I try to save as PDF, they aren’t visible either, only the rectangle. I haven’t been able to find a solution for this anywhere so far… any suggestions? I tried to include screenshots to demonstrate what I meant but the files were too large to post.
I’m using QGIS 3.10 on a Mac running macOS Catalina.
Cheers in advance!
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200726/bc025a89/attachment.html>
