[Qgis-user] Font Awesome symbols in QGIS
Nyall Dawson
nyall.dawson at gmail.com
Mon Jul 27 17:43:49 PDT 2020
On Mon, 27 Jul 2020 at 21:08, Jonathan Moules
<jonathan-lists at lightpear.com> wrote:
> I'd be happy to do that, though I'd note that what one person thinks is
> useless, would be useful to another person. Sure I'm struggling to
> conceive of a use for "alignment" or "bezier-curve", but a quick look
> suggests probably over 50% would be potentially useful. Over 80% if you
> remain open minded about how people use these things.
That's the kind of ones I was referring to. Also stuff like volume
up/down, battery indicators, the calender +/-/check icons, most of the
"hand" ones, a bunch of the "user" ones. I can't see those EVER being
used in a map! By the time you remove them and all the brand ones then
you're probably down to about 20% of the original set.
Nyall
> Cheers,
> Jonathan
> > I second Regis plan: if someone forks (or even clones) the github repo, and creates a simple script to morph it a little to resemble the structure you need for the 'QGIS Resource Sharing' Plugin to work (see [0] as simple example and [1] for the nice documentation of it), the icons are one click away for users (plus another one to install the plugin).
> > And the more proper Resource set's we are having, the better our style/icon resources will get.
> > Regards,
> > Richard Duivenvoorde
> > [0] https://github.com/rduivenvoorde/qgis-styles/
> > [1] https://qgis-contribution.github.io/QGIS-ResourceSharing/
