[Qgis-user] Font Awesome symbols in QGIS
Håvard Tveite
havard.tveite at nmbu.no
Tue Jul 28 16:09:57 PDT 2020
Great, Charles!
I took the liberty to add the "Entire Font Awesome Free repo"
to the directory of approved repositories for QGIS Resource
Sharing.
I installed the collection, and the QGIS Resource Sharing plugin
reported that 1601 SVG files were recognised in the collection.
The SVGs also showed up under "User Symbols-> Font Awesome icons"
in the SVG groups.
Let me know if you would like me to remove it from the directory.
Håvard
On 28.07.2020 23:57, Charles Dixon-Paver wrote:
> I hacked together a band-aid solution. Probably not production ready but
> I would advocate for this system of having a small subset of these icons
> included in QGIS core by default going forward (If any. It may be better
> to just start a similar svg-library specifically for cartography, but
> using what's available is a start I guess.).
> Pretty much any application specific purposes are well catered for by
> the resource sharing plugin IMO.
> Cherry picked list of Font-Awesome icons for general map purposes:
> https://github.com/zacharlie/fa4qgis
> Entire Font Awesome Free repo to use with the QGIS Resource Sharing Plugin:
> https://github.com/zacharlie/fa4gis
> Happy to hand over custodianship of these to anyone who thinks they're
> up to it .
> If people find these useful I could probably do similar for similar
> libraries like feather, material or unicons.
> Regards
> On Tue, 28 Jul 2020 at 13:28, Jonathan Moules
> <jonathan-lists at lightpear.com <mailto:jonathan-lists at lightpear.com>> wrote:
> > but these use cases seem pretty fringe to me (no for general use).
> Yes, and this then raises the question: how fringe is too fringe? An
> ecologist is going to want a different set of symbols to a transport
> planner to a meteorologist to a defence planner to a hydrologist to
> a school teacher to a archaeologist to a geologist to a....
> Should default QGIS only be suitable for creating generic city-level
> maps? With few exceptions that seems to be all the current SBG
> symbols are aimed at (that and depicting multi-cultural religious
> stuff... :-? ). Sure, that's a good base, but how many people
> actually do just that?
> The thing with complex tools like QIGS is that outside of the core,
> everyone uses different features. I'd point out that QGIS already
> has numerous tools that are to some degree domain specific
> (explicitly or implicitly): Hydrology, Network Analysis,
> Geostatistics, etc. Assuming sensible tooling around discovering
> like the Processing Toolbox now has, I think more icons would make
> things better for everyone. I'm definitely not suggesting adding all
> icons, but certainly a healthy chunk of new ones to cover a larger
> set of use-cases than the current set do.
> On 2020-07-28 11:24, Charles Dixon-Paver wrote:
>> No to waylay to furore, but these use cases seem pretty fringe to
>> me (no for general use) and are the type of thing that is catered
>> for by the resource sharing plugin.
>> If the goal is to improve usability, including all of the fa icons
>> seems counter intuitive to me.
>> Regards
>> On Tue, 28 Jul 2020 at 11:58, Jonathan Moules
>> Hi Nyall,
>> The problem is it's near impossible to know what people will
>> use for symbology.
>> > battery indicators
>> Charging stations; indicators of expected charge during a
>> Battery operated vehicle event; etc [although probably only
>> need the empty one; the full rest can be created with
>> symbology and a rectangle]
>> > volume
>> Mapping a festival; tracking noise complaints; etc
>> > most of the "hand" ones
>> I'd probably keep about half of them. The rotation variants
>> are not needed of course, but quite a few hands could be used:
>> hand-wash (I hear there's something going around...),
>> hand-pointer, praying-hands, handshake, hand-rock,
>> hand-holding (the variants can be created by symbology),
>> hands, hand-sparkles. I can think of uses for all of these.
>> It's obviously subjective but I'd lean on the side of
>> including ones that look like they could be useful, especially
>> given the suggestions around categorisation and search in my
>> other thread which would improve discoverability. Remember
>> people make maps of all manner of crazy things, and often
>> subvert one symbol to mean another thing (with some tweaking)
>> [or maybe that's just me ;-) ].
>> Cheers,
>> Jonathan
>> On 2020-07-28 01:43, Nyall Dawson wrote:
>>> On Mon, 27 Jul 2020 at 21:08, Jonathan Moules
>>> <jonathan-lists at lightpear.com> <mailto:jonathan-lists at lightpear.com> wrote:
>>>> I'd be happy to do that, though I'd note that what one person thinks is
>>>> useless, would be useful to another person. Sure I'm struggling to
>>>> conceive of a use for "alignment" or "bezier-curve", but a quick look
>>>> suggests probably over 50% would be potentially useful. Over 80% if you
>>>> remain open minded about how people use these things.
>>> That's the kind of ones I was referring to. Also stuff like volume
>>> up/down, battery indicators, the calender +/-/check icons, most of the
>>> "hand" ones, a bunch of the "user" ones. I can't see those EVER being
>>> used in a map! By the time you remove them and all the brand ones then
>>> you're probably down to about 20% of the original set.
>>> Nyall
>>>> Cheers,
>>>> Jonathan
>>>>> I second Regis plan: if someone forks (or even clones) the github repo, and creates a simple script to morph it a little to resemble the structure you need for the 'QGIS Resource Sharing' Plugin to work (see [0] as simple example and [1] for the nice documentation of it), the icons are one click away for users (plus another one to install the plugin).
>>>>> And the more proper Resource set's we are having, the better our style/icon resources will get.
>>>>> Regards,
>>>>> Richard Duivenvoorde
>>>>> [0]https://github.com/rduivenvoorde/qgis-styles/
>>>>> [1]https://qgis-contribution.github.io/QGIS-ResourceSharing/
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
