[Qgis-user] Requesting help with Satellite layer
Wanda Norman
wanda.mnorman2015 at gmail.com
Fri Jul 31 07:54:09 PDT 2020
Hello,
I am a new user and I am trying to add a satellite layer to a project
in QGIS 3.14 (non-MAC pc). I need to be able to do this on a regular basis
so I am trying to learn how.
The steps I have taken are following this tutorial:
https://www.geodose.com/2017/08/adding-free-satellite-imagery-layer-qgis.html
The image is added to my project but I get these errors:
1) for development purposes only shows up on the layer
2) I get this message log error:
2020-07-31T10:02:12 WARNING Python error : Couldn't load plugin
'ee_plugin' due to an error when calling its classFactory() method See
message log (Python Error) for more details.
2020-07-31T10:13:36 WARNING Python error : An error has occurred
while executing Python code: See message log (Python Error) for more
details.
2020-07-31T10:13:36 WARNING OpenLayers Plugin : Printing and
rotating of Javascript API based layers is currently not supported!
3) if I try to move the satellite layer (up or down in my list) I get this
error: This page can't load Google Maps correctly. with this Python error:
2020-07-31T10:02:12 CRITICAL Traceback (most recent call last):
File
"C:\Users\Annaka\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\ee_plugin\extlibs_windows\ee\data.py",
line 230, in get_persistent_credentials
tokens = json.load(open(oauth.get_credentials_path()))
FileNotFoundError: [Errno 2] No such file or directory:
'C:\\Users\\Annaka/.config/earthengine/credentials'
During handling of the above exception, another exception
occurred:
File
"C:/Users/Annaka/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\ee_plugin\ee_auth.py",
line 19, in init
ee.Initialize()
File
"C:\Users\Annaka\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\ee_plugin\extlibs_windows\ee\__init__.py",
line 114, in Initialize
credentials = data.get_persistent_credentials()
File
line 241, in get_persistent_credentials
'Please authorize access to your Earth Engine account by '
ee.ee_exception.EEException: Please authorize access to your
Earth Engine account by running
earthengine authenticate
in your command line, and then retry.
occurred:
File "C:/PROGRA~1/QGIS
3.14/apps/qgis/./python\qgis\utils.py", line 334, in _startPlugin
plugins[packageName] = package.classFactory(iface)
File
"C:/Users/Annaka/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\ee_plugin\__init__.py",
line 25, in classFactory
from .ee_plugin import GoogleEarthEnginePlugin
3.14/apps/qgis/./python\qgis\utils.py", line 743, in _import
mod = _builtin_import(name, globals, locals, fromlist, level)
File
"C:/Users/Annaka/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\ee_plugin\ee_plugin.py",
line 26, in
ee_plugin.ee_auth.init()
File
line 21, in init
authenticate()
File
line 32, in authenticate
auth_url = ee.oauth.get_authorization_url()
TypeError: get_authorization_url() missing 1 required
positional argument: 'code_challenge'
2020-07-31T10:13:36 WARNING NotImplementedError:
QgsPluginLayer.setTransformContext() is abstract and must be overridden
2020-07-31T10:20:56 WARNING TypeError: writeXml() takes 3 positional
arguments but 4 were given
I have been using the tutorials to learn how to use this software, so I
apologize for the lack of knowing what I am doing :-)
I would appreciate any assistance!
Thank you,
Wanda Norman
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200731/2a7ab590/attachment-0001.html>
