[Qgis-user] Requesting help with Satellite layer
Ujaval Gandhi
ujaval at spatialthoughts.com
Fri Jul 31 08:05:19 PDT 2020
Hi Wanda,
Please use the QuickMapServices plugin instead of OpenLayers - which is the
preferred way to get different basemaps. Once installed, you can go
to QuickMapServices -> Settings and get the 'Contributed Pack' to get
access to many more basemaps.
The other error you are seeing is from the Google Earth Engine plugin and
related to authentication. If you use that plugin, you will need to re-run
authentication. See FAQ
<https://github.com/gee-community/qgis-earthengine-plugin>
[image: Logo] <https://spatialthoughts.com/>
Ujaval Gandhi
Spatial Thoughts
mobile: +91-8095684687
email: ujaval at spatialthoughts.com
[image: LinkedIn icon] <https://www.linkedin.com/in/spatialthoughts/> [image:
Twitter icon] <https://twitter.com/spatialthoughts>
Subscribe to our newsletter http://bit.ly/spatialthoughts-newsletter
On Fri, Jul 31, 2020 at 8:18 PM Wanda Norman <wanda.mnorman2015 at gmail.com>
wrote:
> Hello,
> I am a new user and I am trying to add a satellite layer to a project
> in QGIS 3.14 (non-MAC pc). I need to be able to do this on a regular basis
> so I am trying to learn how.
> The steps I have taken are following this tutorial:
> https://www.geodose.com/2017/08/adding-free-satellite-imagery-layer-qgis.html
> The image is added to my project but I get these errors:
> 1) for development purposes only shows up on the layer
> 2) I get this message log error:
> 2020-07-31T10:02:12 WARNING Python error : Couldn't load plugin
> 'ee_plugin' due to an error when calling its classFactory() method See
> message log (Python Error) for more details.
> 2020-07-31T10:13:36 WARNING Python error : An error has occurred
> while executing Python code: See message log (Python Error) for more
> details.
> 2020-07-31T10:13:36 WARNING OpenLayers Plugin : Printing and
> rotating of Javascript API based layers is currently not supported!
> 3) if I try to move the satellite layer (up or down in my list) I get this
> error: This page can't load Google Maps correctly. with this Python error:
> 2020-07-31T10:02:12 CRITICAL Traceback (most recent call last):
> File
> "C:\Users\Annaka\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\ee_plugin\extlibs_windows\ee\data.py",
> line 230, in get_persistent_credentials
> tokens = json.load(open(oauth.get_credentials_path()))
> FileNotFoundError: [Errno 2] No such file or directory:
> 'C:\\Users\\Annaka/.config/earthengine/credentials'
> During handling of the above exception, another exception
> occurred:
> File
> "C:/Users/Annaka/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\ee_plugin\ee_auth.py",
> line 19, in init
> ee.Initialize()
> File
> "C:\Users\Annaka\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\ee_plugin\extlibs_windows\ee\__init__.py",
> line 114, in Initialize
> credentials = data.get_persistent_credentials()
> File
> line 241, in get_persistent_credentials
> 'Please authorize access to your Earth Engine account by '
> ee.ee_exception.EEException: Please authorize access to your
> Earth Engine account by running
> earthengine authenticate
> in your command line, and then retry.
> occurred:
> File "C:/PROGRA~1/QGIS
> 3.14/apps/qgis/./python\qgis\utils.py", line 334, in _startPlugin
> plugins[packageName] = package.classFactory(iface)
> File
> "C:/Users/Annaka/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\ee_plugin\__init__.py",
> line 25, in classFactory
> from .ee_plugin import GoogleEarthEnginePlugin
> 3.14/apps/qgis/./python\qgis\utils.py", line 743, in _import
> mod = _builtin_import(name, globals, locals, fromlist, level)
> File
> "C:/Users/Annaka/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\ee_plugin\ee_plugin.py",
> line 26, in
> ee_plugin.ee_auth.init()
> File
> line 21, in init
> authenticate()
> File
> line 32, in authenticate
> auth_url = ee.oauth.get_authorization_url()
> TypeError: get_authorization_url() missing 1 required
> positional argument: 'code_challenge'
> 2020-07-31T10:13:36 WARNING NotImplementedError:
> QgsPluginLayer.setTransformContext() is abstract and must be overridden
> 2020-07-31T10:20:56 WARNING TypeError: writeXml() takes 3
> positional arguments but 4 were given
> I have been using the tutorials to learn how to use this software, so I
> apologize for the lack of knowing what I am doing :-)
> I would appreciate any assistance!
> Thank you,
> Wanda Norman
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200731/d90d3762/attachment.html>
