[Qgis-user] Question On "BallPark Transform"
Randal Hale
rjhale at northrivergeographic.com
Tue Mar 10 17:46:04 PDT 2020
Nyall had requested I submit a bug report...which I forgot
about....until now soooo -> https://github.com/qgis/QGIS/issues/34983
I added your explanation as a comment to the original email.
Randy
I added your message as a comment
On 3/10/20 2:09 PM, Michael.Dodd wrote:
> Is there any more news on this 'bug' as it appears to be serious or it
> might simply be the wording.
> Example:
> Project created in old version of qgis and opened in recent version.
> It comes up with the message about "Ballpark Transformations" and
> suggests installing proj-datumgrid-europe-1.5.zip to enable a better
> transformatoin between epsg:27700 and epsg:4326. The project contains
> the OS GB1936 system and WGS84.
> So I installed the relevant .gsb files in the correct directory with
> the other .gsb files, restarted and tried again to open the project.
> This time it did not come up with the message suggesting the download
> but instead just suggested using one of the other transformations
> which are less accurate than the proper OSTN15_NTv2 transformation.
> Need to know why it is doing the less accurate transformation and how
> to get it to do the correct transformation instead.
> *From:* Qgis-user <qgis-user-bounces at lists.osgeo.org> on behalf of
> Randal Hale <rjhale at northrivergeographic.com>
> *Sent:* 27 February 2020 17:56
> *To:* qgis-user at lists.osgeo.org <qgis-user at lists.osgeo.org>
> *Subject:* [Qgis-user] Question On "BallPark Transform"
> CAUTION: This mail comes from outside the University. Please consider
> this before opening attachments, clicking links, or acting on the
> content.
> Greetings,
> I received an email from two users with 3.12 asking about "Ballpark
> Transformations" - the exact phrase was "Used a Ballpark
> transformation from EPSG:4326 to EPSG: 2274".
> I've been able to generate the message twice by:
> * changing the projection of a new project with no data from 4326 to
> 2274
> * adding data with an incorrect spatial extent that I believe was in
> 4326 and applied to a project in 2274 (I think - I currently don't
> have access to that data to confirm)
> I've found mention of it here:
> https://qgis.org/api/classQgsCoordinateTransform.html#a16adb051fafc25058c0040a310f1606b
> <https://qgis.org/api/classQgsCoordinateTransform.html#a16adb051fafc25058c0040a310f1606b>
> The expanded message in QGIS is:
> /*An alternative, ballpark-only transform was used when transforming
> coordinates between *//*EPSG:4326 - WGS 84*//*and *//*EPSG:2274 -
> NAD83 / Tennessee (ftUS)*//*. The results may not match those obtained
> by using the preferred operation:*//**/
> /*Possibly an incorrect choice of operation was made for
> transformations between these reference systems. Check the Project
> Properties and ensure that the selected transform operations are
> applicable over the whole extent of the current project.*/
> If I check the project properties there is no Datum Transformation
> defined after all this happens.
> I'm assuming that if a project has no data and one jumps datums by
> changing the projection it's saying "Hey since there is no data this
> transformation is a "ballpark" i.e. not exact". Is there a preferred
> way to dealing with this after it happens?
> Randy
> Randal Hale
> rjhale at northrivergeographic.com <mailto:rjhale at northrivergeographic.com>
> (p) 423.653.3611
> http://www.northrivergeographic.com
Randal Hale
https://www.northrivergeographic.com
(423)653-3611
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200310/9762a026/attachment.html>
