[Qgis-user] sampling points from multipe rasters
Matt Boyd mattslists at gmail.com
Mon May 4 17:57:24 PDT 2020
Hi Tyler,
the point sampling tool plugin will allow you to select multiple rasters to
sample from and output to the same file. It also allows you to save the
results in a number of different formats (geopackage, csv and shapefile).
If you've got access to python in your version of R then geopandas can read
geopackage files directly, I find that a lot more useful than csv.
I use this workflow. The slowest part is the point sampling depending on
the number and size of rasters and points.
Matt
On Tue, May 5, 2020 at 6:49 AM Tyler Smith <tyler at plantarum.ca> wrote:
> Hi,
> I have 30 raster layers, and I need to sample 10,000 random points
> from each layer (using the same set of points each time). I think
> my options are:
> 1. Create a virtual raster, and sample. This has the downside that
> the identify of the 30 layers will be replaced by generic 'band1',
> 'band2' labels.
> 2. Sample the layers directly, using a batch process. This has the
> downside that it appears to output to gpkg format, and creates 30
> separate files. I will need to open each of these files, export
> the points they contain to csv, and then combine the into a single
> table in R for analysis.
> Is there a way to create a virtual raster that retains the layer
> names in the stack? Alternatively, can I bulk sample multiple
> rasters and have the output combined in a single table?
> Thanks,
> Tyler
> Tyler Smith
> plantarum.ca
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200505/f6c9f25a/attachment.html>
