[Qgis-user] QGIS 3.10: Dimensioning with on-board equipment
Karl Magnus Jönsson Karl-Magnus.Jonsson at kristianstad.se
Tue May 5 01:59:31 PDT 2020
Hi!
Wouldn’t that be round($length,2) for getting two decimal places for meters?
Karl-Magnus Jönsson
Från: Qgis-user <qgis-user-bounces at lists.osgeo.org> För Richard McDonnell
Skickat: den 5 maj 2020 10:51
Till: hdienst47 at aol.com; qgis-user at lists.osgeo.org
Ämne: Re: [Qgis-user] QGIS 3.10: Dimensioning with on-board equipment
In my original response, I mentioned using round(100*( $length) ) || ' cm' which would give you the dimensions in centimetres only.
If you want meters only then remove the 100*, which would look like this round($length) || ' m'
Now if you want both dimensions shown, for example <-- 10.52m (1052cm) -->, then this can be achieved by using the following
round( $length) || ' m' || ' ( ' || round(100*( $length) ) || ' cm)'
Hope that helps!!
Regards,
Richard
Richard McDonnell MSc GIS, FME Certified Professional
FRM Data Management
Oifig na nOibreacha Poiblí
Office of Public Works
Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36
Jonathan Swift Street, Trim, Co Meath, C15 NX36
M +353 87 688 5964 T +353 1 647 6543
https://www.opw.ie
To send me files larger than 30MB, please use the link below https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
Email Disclaimer: https://www.opw.ie/en/disclaimer/
From: Qgis-user <qgis-user-bounces at lists.osgeo.org<mailto:qgis-user-bounces at lists.osgeo.org>> On Behalf Of hdienst47 at aol.com<mailto:hdienst47 at aol.com>
Sent: 01 May 2020 17:15
To: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
Subject: Re: [Qgis-user] QGIS 3.10: Dimensioning with on-board equipment
Hi Richard,
As I had written to you on April 20, I have successfully implemented your proposal.
The only thing missing is an answer to my question:
How would I have to change the command to get a result in m.(,)cm (e.g. 10.52 m or 10,52 m) format?
Regards,
Hartmut
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200505/c10b8e24/attachment.html>
