[Qgis-user] Multi users environment: From geopackage to a database?
Jésahel Benoist
djes1975 at gmail.com
Wed May 6 01:41:38 PDT 2020
Hi Bruno,
I've worked a lot on this issue for two years now. I've started with sqlite
(that was faster and better) but finally I decided to migrate to
geopackage. It was painful at first but now it's OK. But it needs some
rules.
First, I've broken the original big geopackage files into smaller ones. The
users are advised to work only one by one on a specific thematic/file (read
access is possible).
I've created a script to deactivate wal on samba shares, because samba is
the main issue. It contains this only line :
QSettings().setValue("/qgis/walForSqlite3", False)
You should download some tools like Spatialite_GUI
and SQLiteDatabaseBrowser so that you can really work on the db and have
better control. QGIS's dbmanager is a bit limited and sometimes buggy for
sqlite/geopackage, especially with special chars.
Try to work with QGIS internal explorer, it's a tool that has good
export/import functions.
Backup files at least one time a day !
Now with the covid I have created my own online postgis server so that we
can work at home without "help" of IT department and it's GREAT.
Multi-user, faster, smaller, stronger (lol). And some nice capabilities
like spatial filtering ! I highly recommend this.
Questions for all : I've recently discovered this
https://gdal.org/user/virtual_file_systems.html#virtual-file-systems
Wouldn't it be possible to avoid samba's multi-users bug with vsi ?
Jésahel
Le mer. 6 mai 2020 à 09:12, Andreas Neumann <a.neumann at carto.net> a écrit :
> Hi Bruno,
> Unfortunately it is a known issue that Geopackages and QGIS are bad at
> handling simultaneous write and even read requests and developers are
> working on finding solutions (hopefully soon). In single user scenarios
> Geopackages are fine. But Multiuser must be avoided, even for reading only,
> unfortunately.
> As to PostgreSQL vs. Postgis: Postgis is the spatial extension of
> PostgreSQL. If you need geometries (which I assume) than you will need
> Postgis.
> Andreas
> Am 06.05.20 um 08:58 schrieb brunos at mailbox.org:
> Hi
> In my company we are five people who sometimes work with GIS, and we are
> moving from ArcGIS to QGIS (how cool is QGIS and SLYR!) and in this context
> from ESRI file geodatabase to geopackage. Today we run into serious issues
> when two people worked with the same geopackage. I was aware, that it is
> dangerous and unwise to edit the same geopackage from two different
> computers at the same time. But I did not expect both QGIS applications to
> crash immediately and the geopackage to get corrupted. I hoped to get a
> warning or simply not be able to enter edit mode (We later found out, that
> the corrupted geopackage could be recoveredby by adding a new table, this
> somehow fixed it. Whew!).
> Worse, I found that the same thing happens, when I open a QGIS project
> with a layer from a geopackage for display only (no edit mode), which is
> being edited by an other user on an other computer. Again, both QGIS
> application crashed immediately with data loss. Again, the non-responsive
> QGIS tasks could not be killed by windows taskmanager, only by restarting
> of the computers.
> We are using QGIS 3.12.2 on Windows 10. The Geopackages are located on a
> samba network share.
> My questions:
> 1. Is this setup that bad? Do you experience the same fatal consequences
> if someone loads a layer from a geopackage which is being edited by someone
> else? Is there something I do wrong or I that can do to improve the
> situation?
> 2. I realize, that we should probably move from geopackage to a database.
> Do we need PostGIS or can we use PostgreSQL? We don't need more
> functinality than a geopackage offers (exept multi user read/edit
> possibility and stability).
> Many thanks for some hints that put me in the right direction!
> Bruno
> Qgis-user mailing listQgis-user at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200506/16769923/attachment.html>
