[Qgis-user] Reclassify classes vetor points
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Thu May 14 10:33:27 PDT 2020
Hi again,
More info...
You can select the points you want to change manually or by using an expression “class” = ‘D’.
Nicolas Cadieux
Ça va bien aller!
> Le 14 mai 2020 à 13:27, Nicolas Cadieux <nicolas.cadieux at archeotec.ca> a écrit :
> Hi,
> You can select a class and then use the field calculator on those points.
> Nicolas Cadieux
> Ça va bien aller!
>>> Le 14 mai 2020 à 12:39, Marcelo Francisco Sestini <marcelofsestini at gmail.com> a écrit :
>> Esteemed.
>> I'm using version 3.4.
>> I want reclassify points from shapefile. I need to group points
>> that have classes X, Y, Z in class W and points with classes A B, C in class D.
>> How to proceed?
>> Thankful
>> Analista ambiental
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200514/22184028/attachment.html>
