[Qgis-user] Qgis-user Digest, Vol 171, Issue 43
Thayer Young
thayeray at yahoo.com
Wed May 20 08:18:29 PDT 2020
Have you read the log output from the Rasterize tool? You should check that for any errors and make corrections. This part of the training manual documentation is quite old. But the help for the Rasterize tool is up to date. Click on the 'Help' button in the 'Rasterize' dialog, you should be able to figure out what to do from there. In addition to the error log and the Help, please note the following about the Rasterize tool: 1) the Pixel Size, Extent, Width, Height or Dimensions are now located in the "Information" tab of the Layer Properties, 2) you do not want to use your unique id as the burn-in value, and 3) you have to reorganize the extent since in the Layer Properties it is listed xmin,ymin : xmax,ymax, 4) pixels refers to the number of pixels wide or high the raster should be, georeferenced units is the number of feet, meters, or degrees that each pixel should be.
-Thayer
>Date: Mon, 18 May 2020 16:50:11 -0300
>From: jordi badia <jordibadia.arc at gmail.com>
>To: qgis-user at lists.osgeo.org
>Subject: [Qgis-user] problem with chapter 9.4.20 of the exercises
>Message-ID: <b679a453-f74e-503f-8292-de50bb591c2f at gmail.com>
>Content-Type: text/plain; charset=utf-8; format=flowed
>>Hi QGIS, I'm performing the
>https://docs.qgis.org/3.10/es/docs/training_manual/complete_analysis/analysis_exercise.html
>in specifically in chapter 9.4.20 of rendering a vector layer.
>I have installed version 3.10.5-A Coruña, and I do not get to perform
>the rendering, I do not understand where the process is failing after
>trying several methods. I believe that steps 1 to 15 set out in chapter
>9.4.20 currently the website are out of the box for version 3.10.5.
>Could someone update them? or give me some help to prove that I'm doing
>wrong?
>Thank you
>>Jordi Badia
>>jordibadia.arc at gmail.com>-55 41 997418319
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200520/8baf4874/attachment.html>
