[Qgis-user] Topology
Neil B osgeo+qgis at benneb.ca
Sat May 23 14:24:13 PDT 2020
Testing it in QGIS 3.4.
      Processing (Toolbox) ->  Vector geometry -> Polygonize
You give it the linestring layer and it will create polygons wherever there
is an enclosed area. The lines do not require common vertices at the
intersections.
It does allow the ability to create the same attribute structure that's in
the line layer but it doesn't auto populate any values from the associated
lines.
Cheers!
~Neil B.
On Sat, May 23, 2020 at 12:33 PM Pepijn Koops <p.koops82 at gmail.com> wrote:
> Hi, can anyone explain how I can have QGIS transform a map consisting of
> intersectioning lines into a map consisting of neighbouring polygons?
> Many thanks in advance!
> Pepijn Koops
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200523/4683d2f1/attachment.html>
