[Qgis-user] wishing for accurate lattitude/longitude from, a cell phone
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Wed May 27 10:17:08 PDT 2020
Hi Garth,
I am also an archaeologist. We use a single Sxblue 2 from GENEQ. The unit was upgraded by the company so it’s takes in the Russian constellation now. The unit is very precise. When we go out on the field, we let le unit run one a Bench mark for a few hours. We then process that position In PPP or using nrcan gps tower if we are close to one. The company give a really good service helping with both software support and hardware. As everything in made and designed in Québec, they can take the unit appart and change individual parts and chips. We did that one as the Bluetooth chip was now longer capable of working with Windows 10 (more likely the other way around). It had been Made for Windows 95. For a few extra bucks, they changed the gps chip also. The unit is basically a brick (Square and heavy) that connects to an external device like a laptop or a tablet. No screens or anywhere fancy.
https://geneq.com/land-surveying-geomatics/fr/fabricant/sxblue
Nicolas Cadieux
Ça va bien aller!
> Le 27 mai 2020 à 11:19, QGIS.USER <qgis.user at raycar.plus.com> a écrit :
> Hi Garth,
> Thank you for the correction and the additional information. Much appreciated.
> My current thinking is that in the archaeology we do, the intra-site (relative) measurements are quite good but what is inaccurate is the absolute measurements. We can set out our grids with cm accuracy but can only locate them on the ground with 10s of metre accuracy. It would be good to have a low cost way of establishing the absolute position even if that took time and/or was off-line.
> Ray Carpenter,
> Chapel Archaeology
> -----Original Message-----
> From: Garth Fletcher [mailto:garth at jacqcad.com]
> Sent: 27 May 2020 15:25
> To: QGIS.USER; qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] wishing for accurate lattitude/longitude from, a cell phone
> Hi Ray,
> Apologies for the typo - I had typed iGS3, but iG3s is the right number.
> iGage <https://smex-ctp.trendmicro.com:443/wis/clicktime/v1/query?url=www.igage.com&umid=068947a3-968f-435b-8f88-0b9b8eb439a9&auth=276d51547942e21b974d48c8cd7101aa75dd6e1a-f9ccd777f828c1b394629f942585917bb0a34506> iG3s, now replaced by the iG4 which adds Galileo
> tracking but otherwise seems very similar to the iG3s. $2400 US.
> These track satellites from the US GPS, Russian GLONASS, Chinese BeiDou
> and, with the iG4, European Galileo constellations.
> Their sole function is to record from all the satellites they can track.
> They produce a RINEX format file which can be sent to a post processing
> service such as Canada's Geodetic Surveys' CSRS-PPP:
> <https://webapp.geod.nrcan.gc.ca/geod/tools-outils/ppp.php?locale=en>
> The longer the observation (recording) duration, the better CSRS-PPP can
> converge to an accurate location. In my experience in New Hampshire's
> heavily wooded environment, a 30 to 45 minute observation time generally
> gets me to better than ± 1 meter accuracy. Yesterday a 6 hour long
> observation in a small field surrounded by forest converged to within 1
> inch. Dense forest canopy reduces the number of satellites that can be
> tracked. Also, some times of day are better than others in terms of the
> number of satellites and their geometry, see:
> <https://www.gnssplanning.com/#/charts>
> The iG3s was perfect for my specific conditions, but I think it is not
> optimal where many locations within a site must be accurately me
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200527/708c1f27/attachment.html>
