[Qgis-user] query of a layer from another layer in select by expression
Yann Voté ygversil at lilo.org
Thu May 28 13:24:28 PDT 2020
You can try the direct but implicit represent_value() function, if the
filtering is by the referenced column, like this:
represent_value("referencing_field") = 'filter_value_on_referenced_layer'
Or you can try the more verbose and more explicit
attribute()/get_feature() functions, if you want to filter by another
column:
attribute(get_feature('referenced_layer_name', 'referenced_field',
"referencing_field"), 'filter_field') = 'filter_value'
And be careful about quotes: 'foo' (single quotes) is a string (but may
designates a field in other layer in some functiones), while "foo"
(double quotes) designates a field in the active layer.
Hope this helps!
Yann
Le 28/05/2020 à 19:11, Patrick St-Hilaire a écrit :
> Hi !
> Could someone tell me how to query a layer from fields of another layer
> using select by expression? I have already created a relationship
> between my two layers in projects.
> Thank you
> Patrick
> Qgis-user mailing list
