[Qgis-user] Connecting to WMS does not work
    Christoph Jung
    jagodki.cj at gmail.com
    Thu May 28 21:46:42 PDT 2020
Hello everyone,
I have a very strange problem with QGIS. Only one user in my company is not able to connect a external WMS. If we try to connect via the data source manager, a dialog appears with the information, that the host cannot be found. The url of the service is not the problem because it is inserted via a plugin, i.e. all users using the same url. And for all other users it works perfectly. We copied the url from QGIS into the browser and we can get the capabilities. The same url works without problems in other software (Smallworld, GSA, WindPro). The proxy in QGIS is correct. If I remove the proxy settings we get another error message according to the proxy. The parameters for the proxy are the same for all users and also inserted via a plugin to avoid typing errors or something. It is not a problem of a different IP segment or something because only QGIS has this problem and we are not able to reproduce it with other users.
Now the (for me very important ^^) question: does anybody had such a problem in the past or could imagine other possibilities of problems?
Sincerely,
Christoph
