[Qgis-user] Connecting to WMS does not work
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Fri May 29 05:12:02 PDT 2020
What if you installed and old version of QGIS, like 2.18, on the same computer and try again. You can live with a QGIS 2 and QGIS 3 on the same machine. If you continue having the same problem, then you can probably narrow down the problem to some firewall or an Anti-virus software Settings. Could this be linked to the internet setting stating you are on a public network as opposed to a private network? Just shooting from the hip.
Nicolas Cadieux
Ça va bien aller!
> Le 29 mai 2020 à 00:46, Christoph Jung <jagodki.cj at gmail.com> a écrit :
> Hello everyone,
> I have a very strange problem with QGIS. Only one user in my company is not able to connect a external WMS. If we try to connect via the data source manager, a dialog appears with the information, that the host cannot be found. The url of the service is not the problem because it is inserted via a plugin, i.e. all users using the same url. And for all other users it works perfectly. We copied the url from QGIS into the browser and we can get the capabilities. The same url works without problems in other software (Smallworld, GSA, WindPro). The proxy in QGIS is correct. If I remove the proxy settings we get another error message according to the proxy. The parameters for the proxy are the same for all users and also inserted via a plugin to avoid typing errors or something. It is not a problem of a different IP segment or something because only QGIS has this problem and we are not able to reproduce it with other users.
> Now the (for me very important ^^) question: does anybody had such a problem in the past or could imagine other possibilities of problems?
> Sincerely,
> Christoph
> Qgis-user mailing list
