[Qgis-user] Save projects to DB without creator's permissions
Alessandro Pasotti
apasotti at gmail.com
Fri May 29 12:02:49 PDT 2020
Maybe all that you need is in the QHIS auth system is
https://docs.qgis.org/3.10/en/docs/user_manual/auth_system/auth_workflows.html#changing-authentication-config-id
The master password can be stored in the operating system wallet so that
the user will not need to type his password.
Regards
On Fri, May 29, 2020, 19:39 Cliff Patterson <cpatterson at psdrcs.com> wrote:
> PS: I realize I can create maps with basic auth and not store the PW,
> which prompts the user to enter their creds. But is there a better way now
> to achieve the same result?
> Cliff
> On Fri, May 29, 2020 at 1:29 PM Cliff Patterson <cpatterson at psdrcs.com>
> wrote:
>> What is the best approach to save QGIS projects to PostgreSQL
>> without saving the project-creator's credentials/permissions? If the DB
>> admin creates a project and saves it to the DB, anyone opening that project
>> will attain the admin's permissions on layers in that map.
>> To recreate:
>> 1) Create a map containing PostGIS layers and save project to DB. All
>> layers should be editable by the admin. Admin is logged into DB with auth
>> config, not basic auth.
>> 2) Create a new read-only user and new profile in QGIS and log in to DB.
>> 3) Open the project and try to edit layers. Read-only user will be able
>> to see and edit all layers just like the DB Admin.
>> Is there a way to save projects to DB WITHOUT saving any user
>> creds/permissions?
>> Cliff
>> Cliff Patterson Ph.D.
>> *PSD* | Senior GIS Consultant
>> P: 519-690-2565 ext. 2616
>> www.psdrcs.com
>> London | 148 Fullarton St. 9th Floor
> www.psdrcs.com
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200529/b26dc4c6/attachment.html>
