[Qgis-user] flatpak qgis on CentOS 7 hangs on Project Save after displaying dbus error
Nyall Dawson
nyall.dawson at gmail.com
Sun Nov 1 14:25:03 PST 2020
On Mon, 2 Nov 2020 at 08:17, Todd Pfaff <pfaff at rhpcs.mcmaster.ca> wrote:
> Since I got no response to this, I've given up on the flatpak deployment
> of QGIS.
Just a heads-up -- neither the Flatpak nor anaconda releases are
supported by QGIS.org. For all support for these you'd need to reach
out to their corresponding communities, not the upstream QGIS support
platforms.
Hope that clarifies!
Nyall
> After seeing a different problem report from another flatpak QGIS user on
> this list, and seeing them mention the Anaconda QGIS installation, I've
> reinstalled QGIS with the latest version of Anaconda3 for linux x86_64 and
> the problem I was having with flatpak QGIS is resolved.
> On Tue, 20 Oct 2020, Todd Pfaff wrote:
> > I have a flatpak installation of QGIS 3.10, just installed today, on a CentOS
> > 7 system. I launch QGIS from an xterm with the command line:
> > flatpak run --share=network --command=bash org.qgis.qgis \
> > -c "DISPLAY=$DISPLAY qgis $*"
> > When a Project Save is attempted the following messages are displayed in the
> > terminal:
> > Warning: Failed enumerating UDisks2 objects:
> > "org.freedesktop.DBus.Error.Disconnected"
> > "Not connected to D-Bus server"
> > and then QGIS becomes unresponsive and has to be killed with CTRL-C.
> > Anyone have any ideas about what the problem is?
> > Anyone else successfully running flatpak qgis on CentOS 7 and not
> > encountering this problem?
> Qgis-user mailing list
