[Qgis-user] flatpak qgis on CentOS 7 hangs on Project Save after displaying dbus error
Todd Pfaff
pfaff at rhpcs.mcmaster.ca
Sun Nov 1 14:55:43 PST 2020
On Mon, 2 Nov 2020, Nyall Dawson wrote:
> Just a heads-up -- neither the Flatpak nor anaconda releases are
> supported by QGIS.org. For all support for these you'd need to reach
> out to their corresponding communities, not the upstream QGIS support
> platforms.
Not a problem, I certainly wasn't expecting any support from anyone.
This isn't my first foss rodeo - been doing this for 30+ years. I just
followed up here to close the loop on my original posting and to let
others know what worked for me. I'm sure I could install the whole kit
from source if I still had the patience (and lower workload) that I had
decades ago.
I may very well later have to use a different installation method if we
find out that the Anaconda installation isn't up to snuff or is lacking
features needed by the folks that I support, but we'll cross that bridge
when it comes.
I wasn't able to find anything about a Flatpak QGIS community, neither
mentioned on the QGIS installers page which mentions the Flatpak
installer, nor via google, which I tried that before posting anything to
this list. Maybe my google fu is weak.
I wouldn't have even known there was an Anaconda installer for QGIS if I
hadn't happened to be watching this list and seen the post from another
user with a Flatpak problem who mentioned the Anaconda installer.
Perhaps someday someone will update the QGIS Installers page and:
- add your "heads up" note to the Flatpak section,
- add an Anaconda section,
- add your "heads up" note to the Anaconda section,
- replace or augment the ancient RHEL/CentOS section with suggestions to
try the Flatpak and Anaconda installers for more current QGIS versions,
which is known to work as reported by other users on this list but which
is not supported as per the "heads up notes" in those other section.
cheers,
Todd
