[Qgis-user] Opening properties of WMS or XYZ-Tile layer crashing QGIS
Bernd Vogelgesang
bernd.vogelgesang at gmx.de
Wed Nov 4 05:39:40 PST 2020
Hi Pedro,
thanx for the hint.
Will add my case.
Thanks,
Bernd
On 04.11.20 14:22, Pedro Venâncio wrote:
> Bernd,
> It should be related to https://github.com/qgis/QGIS/issues/39693 and
> several others already reported.
> Can you post your case there?
> Best regards,
> Pedro
> Bernd Vogelgesang <bernd.vogelgesang at gmx.de> escreveu no dia quarta,
> 4/11/2020 à(s) 13:17:
>> Hi Alexandre,
>> Brand new in the sense of creating a new project and adding the layer
>> again? Yes, still crashing.
>> But now some strange news: In my new profile, opening the properties
>> works. But now I tried to change a property -> Crash as well! Same error
>> in terminal
>> On 04.11.20 14:12, Alexandre Neto wrote:
>>> Hi Bernd,
>>> What about if you create a brand new connection? Does it still happen?
>>> Alexandre Neto
>>> QGIS Support
>>> www.qcooperative.net
>>> A quarta, 4/11/2020, 12:39, Bernd Vogelgesang <bernd.vogelgesang at gmx.de>
>>> escreveu:
>>>> Hi,
>>>> all in sudden in my default profile, each attempt to open the properties
>>>> of WMS layer or XYZ leads to an immediate crash of QGIS. (3.16 Linux
>> Mint)
>>>> Starting QGIS from terminal it shows this while crashing:
>>>> QGIS died on signal 11Could not attach to process. If your uid matches
>>>> the uid of the target
>>>> process, check the setting of /proc/sys/kernel/yama/ptrace_scope, or try
>>>> again as the root user. For more details, see
>> /etc/sysctl.d/10-ptrace.conf
>>>> ptrace: Vorgang nicht zulässig.
>>>> No thread selected
>>>> No stack.
>>>> gdb returned 0
>>>> In a relatively new and clean profile, this does not happen.
>>>> I so far uninstalled some lately installed plugin but to no avail, then
>>>> I at least deactivated all other plugins. No change in behaviour.
>>>> Can anyone point me to the source of the problem?
>>>> Cheers,
>>>> Bernd
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
