[Qgis-user] Opening properties of WMS or XYZ-Tile layer crashing QGIS
Pedro Venâncio
pedrongvenancio at gmail.com
Wed Nov 4 05:22:37 PST 2020
Bernd,
It should be related to https://github.com/qgis/QGIS/issues/39693 and
several others already reported.
Can you post your case there?
Best regards,
Pedro
Bernd Vogelgesang <bernd.vogelgesang at gmx.de> escreveu no dia quarta,
4/11/2020 à(s) 13:17:
> Hi Alexandre,
> Brand new in the sense of creating a new project and adding the layer
> again? Yes, still crashing.
> But now some strange news: In my new profile, opening the properties
> works. But now I tried to change a property -> Crash as well! Same error
> in terminal
> On 04.11.20 14:12, Alexandre Neto wrote:
> > Hi Bernd,
> > What about if you create a brand new connection? Does it still happen?
> > Alexandre Neto
> > QGIS Support
> > www.qcooperative.net
> > A quarta, 4/11/2020, 12:39, Bernd Vogelgesang <bernd.vogelgesang at gmx.de>
> > escreveu:
> >> Hi,
> >> all in sudden in my default profile, each attempt to open the properties
> >> of WMS layer or XYZ leads to an immediate crash of QGIS. (3.16 Linux
> Mint)
> >> Starting QGIS from terminal it shows this while crashing:
> >> QGIS died on signal 11Could not attach to process. If your uid matches
> >> the uid of the target
> >> process, check the setting of /proc/sys/kernel/yama/ptrace_scope, or try
> >> again as the root user. For more details, see
> /etc/sysctl.d/10-ptrace.conf
> >> ptrace: Vorgang nicht zulässig.
> >> No thread selected
> >> No stack.
> >> gdb returned 0
> >> In a relatively new and clean profile, this does not happen.
> >> I so far uninstalled some lately installed plugin but to no avail, then
> >> I at least deactivated all other plugins. No change in behaviour.
> >> Can anyone point me to the source of the problem?
> >> Cheers,
> >> Bernd
> >> _______________________________________________
> >> Qgis-user mailing list
> >> Qgis-user at lists.osgeo.org
> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201104/9103d6e8/attachment.html>
