[Qgis-user] Opening properties of WMS or XYZ-Tile layer crashing QGIS
Bernd Vogelgesang bernd.vogelgesang at gmx.de
Wed Nov 4 05:17:04 PST 2020
Hi Alexandre,
Brand new in the sense of creating a new project and adding the layer
again? Yes, still crashing.
But now some strange news: In my new profile, opening the properties
works. But now I tried to change a property -> Crash as well! Same error
in terminal
On 04.11.20 14:12, Alexandre Neto wrote:
> Hi Bernd,
> What about if you create a brand new connection? Does it still happen?
> Alexandre Neto
> QGIS Support
> www.qcooperative.net
> A quarta, 4/11/2020, 12:39, Bernd Vogelgesang <bernd.vogelgesang at gmx.de>
> escreveu:
>> Hi,
>> all in sudden in my default profile, each attempt to open the properties
>> of WMS layer or XYZ leads to an immediate crash of QGIS. (3.16 Linux Mint)
>> Starting QGIS from terminal it shows this while crashing:
>> QGIS died on signal 11Could not attach to process.  If your uid matches
>> the uid of the target
>> process, check the setting of /proc/sys/kernel/yama/ptrace_scope, or try
>> again as the root user.  For more details, see /etc/sysctl.d/10-ptrace.conf
>> ptrace: Vorgang nicht zulässig.
>> No thread selected
>> No stack.
>> gdb returned 0
>> In a relatively new and clean profile, this does not happen.
>> I so far uninstalled some lately installed plugin but to no avail, then
>> I at least deactivated all other plugins. No change in behaviour.
>> Can anyone point me to the source of the problem?
>> Cheers,
>> Bernd
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
