[Qgis-user] Opening properties of WMS or XYZ-Tile layer crashing QGIS
Alexandre Neto senhor.neto at gmail.com
Wed Nov 4 05:12:08 PST 2020
Hi Bernd,
What about if you create a brand new connection? Does it still happen?
Alexandre Neto
QGIS Support
www.qcooperative.net
A quarta, 4/11/2020, 12:39, Bernd Vogelgesang <bernd.vogelgesang at gmx.de>
escreveu:
> Hi,
> all in sudden in my default profile, each attempt to open the properties
> of WMS layer or XYZ leads to an immediate crash of QGIS. (3.16 Linux Mint)
> Starting QGIS from terminal it shows this while crashing:
> QGIS died on signal 11Could not attach to process.  If your uid matches
> the uid of the target
> process, check the setting of /proc/sys/kernel/yama/ptrace_scope, or try
> again as the root user.  For more details, see /etc/sysctl.d/10-ptrace.conf
> ptrace: Vorgang nicht zulässig.
> No thread selected
> No stack.
> gdb returned 0
> In a relatively new and clean profile, this does not happen.
> I so far uninstalled some lately installed plugin but to no avail, then
> I at least deactivated all other plugins. No change in behaviour.
> Can anyone point me to the source of the problem?
> Cheers,
> Bernd
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201104/5f9f1af5/attachment.html>
