[Qgis-user] Saving project to geopackage
Mike Flannigan
mikeflan at att.net
Wed Nov 4 12:55:33 PST 2020
Thanks. I can live with those restrictions for
many of my maps, so I tried it out. It did not
work for me for some reason.
Log says:
QGIS version: 3.10.10-A Coruña
QGIS code revision: 18698293
Qt version: 5.12.7
GDAL version: 3.0.4
GEOS version: 3.7.3-CAPI-1.11.3 b50468f
PROJ version: Rel. 6.3.1, February 10th, 2020
Processing algorithmâ¦
Algorithm 'Package layers' startingâ¦
Input parameters:
{ 'LAYERS' :
['/media/mike/main1/DDrive/Gnis/2020-CA_Trip_actual-geoj.txt|layername=2020-CA_Trip_actual-geoj','/home/mike/Documents/qgis/MO_2009_County_Boundaries_shp.shp','file:///home/mike/Documents/qgis/oil-gas-wells-in-MO.csv?type=csv&maxFields=10000&detectTypes=yes&xField=Well%20Longitude%20Decimal&yField=Well%20Latitude%20Decimal&crs=EPSG:4326&spatialIndex=no&subsetIndex=no&watchFile=no','/home/mike/Documents/qgis/statep010.shp'],
'OUTPUT' : '/home/mike/Documents/copy3/simple_file', 'OVERWRITE' :
False, 'SAVE_STYLES' : True }
Packaging layer 1/4: 2020-CA_Trip_actual-geoj
Packaging layer failed: Opening of data source in update mode failed
(OGR error: )
Packaging layer 2/4: MO_2009_County_Boundaries_shp
(OGR error: )
Packaging layer 3/4: oil-gas-wells-in-MO
(OGR error: )
Packaging layer 4/4: statep010
(OGR error: )
Error obtained while packaging one or more layers.
Execution failed after 0.77 seconds
Loading resulting layers
Algorithm 'Package layers' finished
Can you see anything wrong with my layers?
Perhaps it doesn't like geojson layer either?
I had "Save layer styles into GeoPackage" selected.
I unchecked that and it still failed with almost the same
error messages:
(OGR error: )
(OGR error: )
(OGR error: )
(OGR error: )
Execution failed after 0.73 seconds
It did create a small 74 KB file, but I suspect
it did not work.
Mike
On 11/4/20 1:35 PM, António Pestana wrote:
> Bas,
> Yes, Package Layers (available from the Processing Toolbox of QGIS)
> seems to be the best tool available. Unfortunately it doesn't accept
> raster layers (as you said) or groups of layers (very important when
> you have to manage a large number of layers). I hope these weaknesses
> will disappear soon ...
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201104/4a491449/attachment.html>
