[Qgis-user] Semi Transparent layer displays as solid fill in output PDF
Charles Dixon-Paver
charles at kartoza.com
Thu Nov 5 22:36:05 PST 2020
I think you will need to share some more specific information on your
environment (QGIS version, Operating system etc), and what export settings
you're using.
I just tried a polygon over an XYZ tile service and the PDF export with
transparency was working on Windows with 3.16, so maybe try updating QGIS
to see if it resolves the issue.
On Fri, 6 Nov 2020 at 04:21, Brent Robertson <
Brent.Robertson at ravensdown.co.nz> wrote:
> Hi,
> I have a polygon layer that is 45% transparent and shows as such in the
> map composer but when exporting to PDF the transparency does not follow
> through. Ie polygon is solid fill so cannot see underlying imagery layer
> beneath.
> Cheers,
> Brent
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201106/fc201dd4/attachment.html>
