[Qgis-user] Semi Transparent layer displays as solid fill in output PDF
silvio.bentzien
silvio.bentzien at protonmail.com
Thu Nov 5 23:10:23 PST 2020
Hey,
assuming you exported with the option 'always export as vector' option checked, try exporting again without it.
Gettings,
Silvio
-------- Original Message --------
On Nov 6, 2020, 03:20, Brent Robertson wrote:
> Hi,
> I have a polygon layer that is 45% transparent and shows as such in the map composer but when exporting to PDF the transparency does not follow through. Ie polygon is solid fill so cannot see underlying imagery layer beneath.
> Cheers,
> Brent
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201106/7f92e494/attachment.html>
