[Qgis-user] Couldn't load SIP module
Bernd Vogelgesang
bernd.vogelgesang at gmx.de
Fri Nov 6 04:14:15 PST 2020
Arghh,
could't you have posted this yesterday ? ;)
Updated my hole machine to Mint 20 cause I had no clue how to upgrade
the Qt-version.
The crash issue is gone, but now I face other problems.
Maybe you could post this solution to the issues, cause I think this is
the only way to get 3.16 running on older Ubuntu/Mint versions.
Cheers,
Bernd
On 06.11.20 11:22, Pedro Ferreira wrote:
> Hi
> Had a problem similar last week after upgrading from QGIS 3.14 to 3.16 on my
> Linux Mint 19.3 machine. The problem I had was If I needed to opening
> properties dialogue for raster, QGIS ended up crashing. After a couple of
> tries removing and reinstalling I've ended up with the SIP error. After
> reeding this post https://github.com/qgis/QGIS/issues/39628 I've found out
> that it could be a Py-Qt5 problem. I've done this:
> 1. Purged QT5 along with QGIS;
> 2. In terminal
> sudo apt install gnupg and software-properties-common
> sudo apt install qgis qgis-plugin-grass
> sudo add-apt-repository ppa:beineri/opt-qt-5.14.2-bionic
> sudo apt update
> sudo apt install qt514-meta-full
> source /opt/qt514/bin/qt514-env.sh
> qgis
> Hope it helps you.
> Pedro
> Pedro Ferreira
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user mailing list
