[Qgis-user] Keeping layers of an imported DXF file into QGIS
Andreas Neumann
andreas at qgis.org
Mon Nov 9 07:25:28 PST 2020
Hi Luc,
Can you share such a dxf with me?
As just written in my other mail (seconds ago), please also try the native
way of importing the DXF to a Geopackage through menu "Project -->
Import/Export --> Import Layers from DWG/DXF"
Andreas
On Mon, 9 Nov 2020 at 16:03, Luc Le Blanc <speleoluc at gmail.com> wrote:
> That's our impression too, as QGIS ends up with (3) layers of shapes,
> lines and text. The problem is that this line layer is a bulk merge of
> several DXF layers representing different things (line plot, passage
> widths, walls, etc.) that the user would like to toggle (hide/show) or
> even exclude from the import. Just knowing the layer of origin is not
> sufficient. Can QGIS act upon these attributes other than just showing
> them? (I'm not a QGIS user, just researching for an Auriga user who
> asked me).
> Le lun. 9 nov. 2020 Ã 09:43, Charles Dixon-Paver <charles at kartoza.com> a
> écrit :
> > I think the DXF is just split by geometry type, but you should be able
> to access the "layer" information via the attributes.
> > On Mon, 9 Nov 2020 at 16:24, Luc Le Blanc <speleoluc at gmail.com> wrote:
> >> Hi,
> >> My cave survey freeware exports DXF files organized in multiple layers
> >> for survey stations, station names, line plot, wall lines, etc.
> >> A user tells me that when he imports this DXF into QGIS, everything
> >> gets merged into 3 layers containing station markers (small
> >> triangles). lines (line plot, passage widths, walls, altogether) and
> >> station names.
> >> Is it possible for QGIS to neatly import a layered DXF file into
> >> corresponding layers, respecting the initial organization?
> >> Luc Le Blanc
> >> http://www.speleo.qc.ca/Auriga
> >> _______________________________________________
> >> Qgis-user mailing list
> >> Qgis-user at lists.osgeo.org
> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Luc Le Blanc
Andreas Neumann
QGIS.ORG board member (treasurer)
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201109/82f3d53f/attachment.html>
