[Qgis-user] Keeping layers of an imported DXF file into QGIS
Charles Dixon-Paver
charles at kartoza.com
Mon Nov 9 07:10:44 PST 2020
The attributes are a core component of many spatial operations and QGIS is
very adept at manipulating them. You can style layers, query/ filter layers
or perform split and aggregation operations using the attribute values.
For your purposes, perhaps start by just splitting layers by the relevant
attribute values. You can access the tool from Vector >> Data Management
Tools >> Split Vector Layer
On Mon, 9 Nov 2020 at 17:03, Luc Le Blanc <speleoluc at gmail.com> wrote:
> That's our impression too, as QGIS ends up with (3) layers of shapes,
> lines and text. The problem is that this line layer is a bulk merge of
> several DXF layers representing different things (line plot, passage
> widths, walls, etc.) that the user would like to toggle (hide/show) or
> even exclude from the import. Just knowing the layer of origin is not
> sufficient. Can QGIS act upon these attributes other than just showing
> them? (I'm not a QGIS user, just researching for an Auriga user who
> asked me).
> Le lun. 9 nov. 2020 Ã 09:43, Charles Dixon-Paver <charles at kartoza.com> a
> écrit :
> > I think the DXF is just split by geometry type, but you should be able
> to access the "layer" information via the attributes.
> > On Mon, 9 Nov 2020 at 16:24, Luc Le Blanc <speleoluc at gmail.com> wrote:
> >> Hi,
> >> My cave survey freeware exports DXF files organized in multiple layers
> >> for survey stations, station names, line plot, wall lines, etc.
> >> A user tells me that when he imports this DXF into QGIS, everything
> >> gets merged into 3 layers containing station markers (small
> >> triangles). lines (line plot, passage widths, walls, altogether) and
> >> station names.
> >> Is it possible for QGIS to neatly import a layered DXF file into
> >> corresponding layers, respecting the initial organization?
> >> Luc Le Blanc
> >> http://www.speleo.qc.ca/Auriga
> >> _______________________________________________
> >> Qgis-user mailing list
> >> Qgis-user at lists.osgeo.org
> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Luc Le Blanc
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201109/7c650d98/attachment-0001.html>
